Не знал куда повесить этот топик... Если что перенесите...
Вот движки, которые были выпущены НИССАНОМ:
http://www.geocities.com/MotorCity/P...3/engines.html
С уважением, Максим.
Была NISSAN 200SX (240, 180) S13 CA18DET (1,8 turbo) 1990г.
ENGINE, SUSPENSION TUNING.
INTERIOR, EXTERIOR STYLING. ее убили...
Honda Civic 5D sport - в прошлом...
OO\_____/OO - любил я ее очень...
Так гараздо интересней
A10 - 988cc - Pushrod 4 Cylinder, 2 barrel down draught carb - 62hp - Sunny B10, 1000, B20 Pick-up
A12 - 1171cc - Pushrod 4 Cylinder, 2 barrel down draught carb - 58hp - Sunny B110&B210, 1200, 1200 Pick-up
A14 - 1397cc - Pushrod 4 Cylinder, 2 barrel down draught carb - 76hp - Sunny B210&B310
A15 - 1488cc - Pushrod 4 Cylinder, 2 barrel down draught carb - 80hp - Sunny B310
C - 988cc - Pushrod 4 Cylinder, 1 barrel down draught carb - 37hp - 210 Bluebird, S211 Sports, 220 Pick-up
C1 - 988cc - Pushrod 4 Cylinder, 2 barrel down draught carb - 45hp - 311 and 312 Bluebird (base model cars)
CA16-DE - 1597cc - DOHC 4 cylinder, 16 valve, twin cam, spark plug, EFI - 113hp - Pulsar Exa Coupe
CA18-DE - 1809cc - DOHC 4 cylinder, 16 valve, twin cam, spark plug, EFI - 130hp - Silvia (1988), Pulsar Exa Coupe
CA18-DET - 1809cc - DOHC 4 cylinder, 16 valve, twin cam, spark plug, EFI - 174hp - Silvia (1988), 180SX, Gazelle, Auster 1800tt
CA20-S - 1974cc - OHC 4 cylinder, 8 valve, twin spark plug, 2 barrel d/d carb - 98hp - Bluebird (1985)
CA20-E - 1974cc - OHC 4 cylinder, 8 valve, twin spark plug, EFI - 104hp - Gazelle (1985)
CG13-DE - 1275cc - DOHC 4 cylinder, twin cam, 16 valve, EFI - 73hp - Micra
D10 - 860cc - Pushrod 4 Cylinder, 1 barrel down draught carb - 25hp - DC-3, 110 sedan, 120 Pick-up
E - 1189cc - Pushrod 4 Cylinder, 1 barrel down draught carb - 48hp - Bluebird 211&310, 222 Pick-up, Fairlady SP212
E1 - 1189cc - Pushrod 4 Cylinder, 2 barrel down draught carb - 60hp - Bluebird 311,312&410, 223&320 Pick-up
E13 - 1270cc - OHC 4 cylinder, 2 barrel down draught carb - 59hp - Pulsar E (1985)
E15 - 1488cc - OHC 4 cylinder, 2 barrel down draught carb - 69hp - Pulsar (1985), Prarie
E16 - 1597cc - OHC 4 cylinder, 2 barrel down draught carb - ??hp - Pulsar (1985)
E15-ET - 1487cc - OHC 4 cylinder, EFI, turbo - 115hp - Pulsar Exa Coupe, Pulsar Turbo
FJ20-E - 1990cc - DOHC 4 cylinder, 16 valve, twin cam, EFI - 150hp - Silvia RS (1982)
FJ20-ET - 1990cc - DOHC 4 cylinder, 16 valve, twin cam, EFI, turbo - 190hp - Silvia RS-X, Gazelle RS-X, Skyline RS-X (1982)
G - 1488cc - Pushrod 4 Cylinder, 2 barrel down draught carb - 77hp - Cedric 30, Junior 40, Caball C140
G - 1488cc - Pushrod 4 Cylinder, single side draught 'SU' carb - 75hp - Fairlady SP310 (1962-1963)
G - 1488cc - Pushrod 4 Cylinder, twin side draught 'SU' carbs - 85hp - Fairlady SP310 (1963-1965)
GA4 - 1484cc - Pushrod 4 Cylinder, 2 barrel down draught carb - 73hp - Prince Skyline ALSIE
GA16-DE - 1595cc - DOHC 4 cylinder, twin cam, 16 valve, EFI - 115hp - Pulsar (1996)
GB30 - 1862cc - Pushrod 4 Cylinder, 2 barrel down draught carb - 83hp - Prince Gloria, Skyline ALSID, Skyline Sport BLRA
GRX-3 - 5954cc - DOHC 12 cylinder, twin cam, 48 valve V12, MFI, dry sump - 580hp - R382 race car
GRX-3 KAI - 5954cc - DOHC 12 cylinder, twin cam, 48 valve V12, MFI, dry sump - 660hp - R383 race car
G1 - 1484cc - Pushrod 4 Cylinder, 2 barrel down draught carb - 73hp - Prince Skyline S50, Miler 430
G2 - 1862cc - Pushrod 4 Cylinder, 2 barrel down draught carb - 96hp - Prince Super Miler 431, Clipper T631
G7 - 1988cc - OHC 6 cylinder, 2 barrel down draught carb - 106hp - Prince Gloria S40, Skyline GTA S54A
G7 - 1988cc - OHC 6 cylinder, triple 2 barrel side draught Weber carbs - 127hp - Prince Skyline GTB S54B
G11 - 2494cc - OHC 6 cylinder, 2 barrel down draught carb - 134hp - Prince Gloria S41
G15 - 1483cc - OHV 4 cylinder, 2 barrel down draught carb, cross flow head - 94hp - Skyline 1500
G18 - 1815cc - OHV 4 cylinder, 2 barrel down draught carb, cross flow head - 105hp - Laurel C30
H - 1883cc - Pushrod 4 Cylinder, 2 barrel down draught carb - 95hp - Cedric 31, Junior 40, Caball C141
H20 - 1982cc - Pushrod 4 Cylinder, 2 barrel down draught carb - 92hp - Junior 41, Caball C142
H20 - 1982cc - Pushrod 4 Cylinder, 2 barrel down draught carb - 99hp - Cedric 130, E20 van
H30 - 2974cc - Pushrod 6 Cylinder, 2 barrel down draught carb - 130hp - President H150, G80 truck
J13 - 1299cc - Pushrod 4 Cylinder, 2 barrel down draught carb - 67hp - Bluebird 411, 520 Pick-up
J13 - 1299cc - Pushrod 4 Cylinder, twin side draught 'SU' carbs - 77hp - Bluebird SS P411-MTK sports sedan
J15 - 1483cc - Pushrod 4 Cylinder, 2 barrel down draught carb - 77hp - 521&620 pick-up
J16 - 1567cc - Pushrod 4 Cylinder, 2 barrel down draught carb - 81hp - Homer T20
J20 - 1973cc - Pushrod 4 Cylinder, 2 barrel down draught carb - 109hp - Cedric 130, Caball C240
K - 2873cc - Pushrod 6 Cylinder, 2 barrel down draught carb - 118hp - Cedric Special 50
KA24-E - 2389cc - OHC 4 cylinder, 12 valve, EFI - 128hp - Pintara (1990)
KA24-DE - 2389cc - DOHC 4 cylinder, twin cam, EFI - 150hp - Pintara (1994)
L13 - 1290cc - OHC 4 cylinder, 2 barrel down draught carb - 77hp - Bluebird 510
L16 - 1595cc - OHC 4 cylinder, 2 barrel down draught carb - 96hp - Bluebird 510, 1600, 521&620 pick-up (USA)
L16 - 1595cc - OHC 4 cylinder, twin side draught 'SU' carbs - 109hp - Bluebird 510 SSS, 1600SSS
L18 - 1770cc - OHC 4 cylinder, 2 barrel down draught carb - 105hp - Bluebird 610, 180B, 720 Pick-up
L18 - 1770cc - OHC 4 cylinder, twin side draught 'SU' carbs - 110hp - Bluebird SSS 610, 180B SSS
L20 - 1998cc - OHC 6 cylinder, 2 barrel down draught carb - 115hp - Cedric 130,230,330&430, Skyline GC10
L20-ET - 1998cc - OHC 6 cylinder, EFI, turbo - 144hp - Skyline (Japan only)
L20B - 1952cc - OHC 4 cylinder, 2 barrel down draught carb - 93hp - Bluebird 810&910, 200B
L23 - 2262cc - OHC 6 cylinder, 2 barrel down draught carb - 123hp - Cedric 130
L24 - 2362cc - OHC 4 cylinder, 2 barrel down draught carb - 130hp - Cedric 130&230, 240C
L24 - 2362cc - OHC 6 cylinder, twin side draught 'SU' carbs - 151hp - 240Z
L24E - 2362cc - OHC 6 cylinder, EFI - 124hp - Skyline (1984)
L26 - 2565cc - OHC 6 cylinder, 2 barrel down draught carb - 138hp - Cedric 230&330, 260C
L26 - 2565cc - OHC 6 cylinder, twin side draught 'SU' carbs - 162hp - 260Z
L28 - 2753cc - OHC 6 cylinder, 2 barrel down draught carb - 139hp - Cedric 330&430, 280C, Patrol
L28 - 2753cc - OHC 6 cylinder, twin side draught 'SU' carbs - 170hp - 280Z, 280ZX
L28E - 2753cc - OHC 6 cylinder, EFI - 180hp - 280C (1983), 280ZX
MA09-ERT - 930cc - OHC 3 cylinder, 6 valve, turbo and supercharged, EFI - 110hp - March Super Turbo (1989)
MA10-ET - 987cc - OHC 3 cylinder, 6 valve, turbo, EFI - 75hp - March Turbo (1988)
P40 - 3956cc - Pushrod 6 Cylinder, 1 barrel down draught carb - 135hp - Patrol
R - 1595cc - Pushrod 4 Cylinder, 2 barrel down draught carb - 81hp - Homer T641
R - 1595cc - Pushrod 4 Cylinder, twin side draught 'SU' carbs - 96hp - Fairlady SP311, Silvia CSP311, Bluebird SSS R411
RB20-DE - 1998cc - DOHC 6 cylinder, 24 valve, twin cam, EFI - 155hp - Laurel, Skyline (1989)
RB20-DET - 1998cc - DOHC 6 cylinder, 24 valve, twin cam, EFI, turbo - 214hp - Skyline GT-S, Cefiro (1989)
RB25-DE - 2498cc - DOHC 6 cylinder, 24 valve, twin cam, EFI - 179hp - Skyline, Cefiro (1992)
RB25-DET - 2498cc - DOHC 6 cylinder, 24 valve, twin cam, EFI, turbo - 250hp - Skyline GT-S25T (1993)
RB26-DETT - 2597cc - DOHC 6 cylinder, 24 valve, twin cam, EFI, twin turbo - 279hp - GODZILLA! Skyline GT-R HR32
RB30-E - 2962cc - OHC 6 cylinder, 12 valve, EFI - 152hp - Skyline (1987)
S20 - 1988cc - DOHC 6 cylinder, 24 valve, twin cam, triple 2 barrel s/d carbs - 160hp - Skyline GT-R KPGC10, Fairlady Z432
SD22 - 2164cc - Pushrod 4 cylinder, diesel - 61hp - 220C, Caball
SD23 - 2289cc - Pushrod 4 cylinder, diesel - 72hp - Urvan (1983)
SD25 - 2499cc - Pushrod 4 cylinder, diesel - 76hp - Navara (1985)
SD33 - 3246cc - Pushrod 6 cylinder, diesel - 94hp - Patrol
SD33T - 3246cc - Pushrod 6 cylinder, diesel, turbo - 108hp - Patrol
SR18-DE - 1838cc - DOHC 4 cylinder, 16 valve, twin cam, EFI - 139hp - Sunny GTS, Pulsar GTi (1992)
SR20-DE - 1998cc - DOHC 4 cylinder, 16 valve, twin cam, EFI - 159hp - Silvia Q (1993), Presea
SR20-DET - 1998cc - DOHC 4 cylinder, 16 valve, twin cam, EFI, turbo - 205hp - Silvia K, 180SX, Pulsar GTiR 4WD (1993)
TD27 - 2663cc - Pushrod 6 cylinder, diesel, cross flow head - 77hp - Navara (1993)
U20 - 1982cc - OHC 4 cylinder, twin side draught 'SU' carbs - 135hp - Fairlady SR311
U20 - 1982cc - OHC 4 cylinder, twin 2 barrel side draught Solex carbs - 150hp - Fairlady SR311
UY - 2 litre - DOHC 6 cylinder, twin cam, 12 spark plug, 2 distributors - ???hp - Fairlady S race car.
VG20-ET - 1998cc - OHC V6, 6 cylinder, 12 valve, EFI, turbo - 170hp - Gloria V20 (1983)
VG30-E - 2960cc - OHC V6, 6 cylinder, 12 valve, EFI - 179hp - Gloria V30E (1983), 300ZX
VG30-ET - 2960cc - OHC V6, 6 cylinder, 12 valve, EFI, turbo - 230hp - 300ZX Turbo (1983)
VG30-DE - 2998cc - DOHC V6, 6 cylinder, twin cam, 24 valve, EFI - 225hp - 300ZX, Leopard (1989)
VG30-DET - 2998cc - DOHC V6, 6 cylinder, twin cam, 24 valve, EFI, turbo - 254hp - Leopard (1990)
VG30-DETT - 2998cc - DOHC V6, 6 cylinder, twin cam, 24 valve, EFI, twin turbo - 278hp - 300ZX Twin Turbo
VG33-E - 3274cc - OHC V6, 6 cylinder, 12 valve - 168hp - Pathfinder, QX4
VH41-DE - 4130cc - DOHC V8, 8 cylinder, 32 valve, EFI - 269hp - Cima 41 (1996)
VH45-DE - 4494cc - DOHC V8, 8 cylinder, 32 valve, EFI - 278hp - Infiniti Q45
VQ30-DE - 2987cc - DOHC 6 cylinder, 24 valve, twin cam, EFI - 230hp - Cedric, Gloria (1996)
VQ30-DET - 2987cc - DOHC 6 cylinder, 24 valve, twin cam, EFI, turbo - 269hp - Cima 30 (1996)
Y40 - 3988cc - Pushrod V8, 8 cylinder, 16 valve, 4 barrel down draught carb - 195hp - President H150
Y44 - 4414cc - Pushrod V8, 8 cylinder, 16 valve, 4 barrel down draught carb - 200hp - President
Z18-ET - 1770cc - OHC 4 cylinder, 8 valve, twin spark plug, EFI, turbo - 135hp - Silvia ZSE-X, Gazelle (1982)
Z20 - 1952cc - OHC 4 cylinder, 2 barrel down draught carb, cross flow head - 88hp - Urvan (1983)
Z22 - 2188cc - OHC 4 cylinder, 2 barrel down draught carb, cross flow head - 95hp - Navara (1985)
Z24 - 2389cc - OHC 4 cylinder, 2 barrel down draught carb, cross flow head - 99hp - 720 Pick-up
Тут не все движки.
нет например легендарного литрового с Микры
и современных тоже нет
не хватает еще чуть-чуть, к примеру нет моторов:
SR16VE
SR20VE
SR20VET
А где мой мотор? обидно ДА :cry:
так у Ромы 159 сил на переднем приводе.
вообщем-то теперь понятно чего он так в дождь вчера ехал
У Ромы 143л.с. в стокеСообщение от Дмитрий
Роме хорошо 8)
Мурчик а у тебя разве не GA16DE ??
Нет у меня карбюратор и 90 конейСообщение от Bend3r
