Correct and Quick Diagnosis EGS000JQ
CHECK THE FOLLOWING ITEMS WITH THE VEHICLE STOPPED.
l Are tire pressure and size proper? Is authorized steering wheel used? Is control unit genuine part?
l Is installation status of steering column and steering gear normal? (mounting bolt looseness, damaged
rods, dust boot, and bulkhead seal, grease leakage)
l Is the wheel alignment adjusted properly?
l Has the vehicle suspension been modified? Has any modification that leads to increased vehicle weight
been made?
l Is installation status of suspension links and axle normal?
l Is battery voltage proper?
l Is connection of each connector normal?
Torque Sensor Malfunction EGS000JV
Inspection Procedure
1. INSPECTION OF CONTROL UNIT CONNECTOR
1604
1. Turn ignition switch OFF and disconnect control unit connectors. Check terminals for deformation, discon-
nection, and looseness. If there is any non-standard condition, repair or replace it.
2. Reconnect connectors securely, and perform self-diagnosis.
Is “Torque sensor malfunction” displayed in self-diagnosis display?
YES >> Replace column assembly.
NO >> Poor connection of connector terminal
1606: Motor Malfunction EGS000JX
Is “Motor malfunction” displayed in self-diagnosis display?
1608: Control Unit Malfunction EGS000JZ
Is “Control unit malfunction” displayed in self-diagnosis display?
1000: CAN Communication System EGS000K0
Is “CAN communication system” indicated in self-diagnosis display?
YES >> Go to LAN-5, "Precautions When Using CONSULT-II" .
Vehicle speed signal error Vehicle speed signal received with CAN communication has error.
коротко: я бы искал в проводах и фишках. причем не обязательно самой колонки - шина CAN по всей машине уложена.
Primera P10 хетчбек запчасти
Primera P10 седан запчасти
200 sx s13 Запчасти
Фото всего этого добра
спасибо! Покажу автоэлектрику - помотрим что он на это скажет. Действительно расшифровку этих кодов он не знал где найти)))
в микра-мануале, раздел STC вроде...
200 sx s13 Запчасти
Значит так . Сам усилитель на разборке стоит 300-350 баксов . Поменять его можно за пару часов , только инструмент нужно не китайский и фонарик -) , ну еще габариты мастера поменьше - лежать головой под торпедой а ногами на сиденье немного тяжко . Перед тем как открутите старый усилитель внимательно осмотрите клеммы на новом - у вас должно быть представление как их подключить на ощупь . Приготовте кусок мягкой проволки что бы подвесить усилитель при снятии - клеммы там можно отключить только открутив его , а когда открутите он повиснет на проводах и может их оборвать . Весит эта дура килограмм 10 и держать его на "весу" одной рукой а другой пробовать снять-поставить клеммы это жесть.... Именно так в моем случае и было ... Вспомнил я япона мать не раз и не два -) Но все ок!
Перед покупкой усилителя не поленитесь проверить предохранители под капотом и в салоне - может где то там проблема ...
