Показано с 51 по 60 из 124
Тема: Новый взгляд на Сильвию?
Древовидный режим
    Кандидат Ниссановских Наук Аватар для autofix
    zaporozhec
    По умолчанию "Практика корчестроения, часть 2" Марк Мазуровский 2008 год
    Дядя Марк Мазуровский опять удивляет
    Mazworx/PRL Racing Pro Modified Drag S15
    NDRA Pro Modified
    SR22VET
    Engine
    Mazworx Build SR22VET
    90.0mm 11:1 CR CP Pistons
    86.0mm OEM Nissan Crankshaft
    Mazworx Custom ALuminum Connecting Rods
    Calico Coated ACL Race Bearings
    Darton Sleeves
    Aviaid Dry Sump Pump
    Mazworx Dry Sump Oil Pan
    ATI Dampner
    Mazworx/Power Enterpise 90mm Headgasket
    Mazworx 1/2" Headstuds
    Mazworx CNC Ported Cylinder Head
    Mazworx CNC Combustion Chambers
    Supertech Valetrain w/ Inconel Exhaust Valves
    Nissan SR16VE N1 Cams
    Mazworx Custom Shimless VE Head
    Tomei Cam Gears
    Power
    Fuel-Methonal
    Mazworx Custom Intake Manifold
    OEM Nissan Q45 Throttle Body
    Mazworx Silicone Couplers
    Garrett GT4508R 1.44A/R
    Mazworx Divided Exhaust Manifold
    Tial 60 Wastegate
    5" Stainless Downpipe
    6" Turbo Intake
    Mechanical Fuel Pump
    12 x 160lb Fuel Injectors
    Electronics
    Motec M880 ECU
    Motec CDI 8 Ignition
    Motec ADL Dash Logger
    Custom Engine/Body Harness
    Motec Complete Data Aquistion
    Denso Coils
    MSD/KONI Shock Controller
    16 Volt System
    Drivetrain
    RAM Dual 7" Slipper Clutch
    Browell Aluminum Bellhousing
    G-Force 2000 Transmission
    Custom 4" Aluminum Driveshaft
    Strange Pro 3rd Member
    Strange Spool w/ 40 Spline Gun Drilled Axles
    American Racing 15 x 15 Double Bead Lock Rear Wheels
    AMerican Racing 15 x 3-1/2 Spindle Mount Front Wheels
    Goodyear 32.0 x 14.5 x 15 Rear Tires
    Goodyear 23.0 x 5.0 x 15 Front Tires
    Chassis
    Mazworx Custom 25.1E Chrome-Moly Chassis, RHD
    Strange Ultra Struts
    Koni Electronic Adjustable Rear Shocks
    Mazworx Custom Rear Housing
    Quartermax Pro 4-Link
    Quartermax Pro Wheelie Bars
    Body
    2000 Nissan Silvia S15 Body
    Custom Fiberglass One-Piece Front End, Doors, Trunk
    Lexan Windows
    Mazworx Rear Spoiler
    Interior
    Carbon Fiber Tubs
    Carbon Fiber Defuser
    Carbon Fiber Panels
    Custom Fiberglass Dash
    Safety
    Strange Front/Rear Brakes
    Safecraft Halon System
    Stroud Harnesss
    Stroud Window Net
    Sparco Steering Wheel
    Sparco Steering Wheel Disconnect
    Stroud Pro Stock Air Assisted Parachutes
    Quartermax Remote Disconnect
    Driver
    Jason Greenawalt
    Crew Chief
    Mark Mazurowski
    Owner
    Patrick Linn
    Последний раз редактировалось autofix; 28.03.2008 в 03:28.
  1. Взгляд со стороны
    от Микрик в разделе Улыбнись! (ех-Юмор)
    Последнее сообщение: 19.02.2009, 10:17
  2. Взгляд изнутри
    Ответов: 22
    Последнее сообщение: 17.06.2008, 18:22
  3. Суппорта 4-eх поршневые на Сильвию
    от Дмитрий в разделе Стайлинг и тюнинг
    Ответов: 19
    Последнее сообщение: 17.08.2005, 10:14
