Страница 4 из 4 ПерваяПервая 1234
Показано с 31 по 36 из 36
Тема: Стоит ли брать битый nissan 200sx
  1. #31
    АЗЛК Драйвер :)
    Аватар для 200smax
    BMW 525TD tour E61
    Цитата Сообщение от Дмитрий
    200smax, при всем уважении к тебе RB и СА ничего общего не имеют. НИЧЕГО.
    Витёк, самый надежный способ проверки - замена
    Да ты что!
    The CA engine is a 1.6 L to 2.0 L Inline-4 piston engine from Nissan designed for a variety of small Nissan vehicles. It is an iron block, aluminum head design with a timing belt. Earlier versions featured SOHC and 8 valves. Later versions featured DOHC with 16 valves for increased high RPM efficiency and smoother power delivery. It is effectively a Nissan RB block with two less cylinders. Components from valves to lifters, as well as bearings, are similar if not identical to the RB and VG series engines. The motor was expensive to produce being cast iron, so it was replaced in 1991 by the SR series as the primary Nissan 4 cylinder engine.
    The CA series engine was the workhorse of the 1980s and was a bulletproof little engine. The power ratings were heavily choked by emissions regulations and Nissan's desire for high gas mileage. The CA design ended in 1990 with the ultimate CA engine, the CA18DET.
    Первоисточник:
    http://en.wikipedia.org/wiki/Nissan_CA_engine
    А здесь про РБхи:
    The RB engine is a 2.0L to 3.0L straight-6 piston engine from Nissan.
    It has an aluminum head with both SOHC/DOHC versions, with the SOHC versions having 2 valves per cylinder and the DOHC versions having 4 valves per cylinder, all cam lobes move only one valve. All RB engines have belt driven cams and a cast iron block. All turbo models have an intercooled turbo (except the single cam RB20ET & RB30ET engines), and most have a recirculating factory blow off valve (except when fitted to Laurels and Cefiros) to reduce boost surge when the throttle is closed.
    Some sources indicate the 'RB' name stands for 'Race Bred'[1], although this is disputed. The Nissan CA engine is a 4 cylinder design derived from the RB engine.
    Первоисточник:
    http://en.wikipedia.org/wiki/Nissan_RB_engine
    Я бы не был столь катигоричным!
    С уважением, Максим.
    ENGINE, SUSPENSION TUNING.
  2. #32
    Кандидат Ниссановских Наук
    Аватар для Andruxa
    Симферополь
    Pajero Sport 2,5 TURBO
    +1
    Паджеро Спорт 2.5 ТУРБО
    ВАЗмерка- Rally edition
  3. #33
    Коростень-Киев
    TOYOTA CAMRY CV20 2.0TURBO
    Цитата Сообщение от Микрик
    Ребята помимо того что машина без мордs? так она еще два года простояла на улице - да там покупать просто нечего. Даже за 1000....
    Внатуре только документы покупаешь....
    Я абсолютно согласен! но попробуй это объяснить продавцу...
  4. #34
    Наваристый Мембер
    Аватар для Микрик
    Дизельная микра
    rcman, пускай еще года два попродает - там тока пластмасовые заглушки остануться ага....
  5. #35
    Коростень-Киев
    а оно так и будет!
  6. #36
    Столица Голодомории
    S13, 91, sr20det
    В общем, rcman, это дорого, брать не советуем.
    Витёк, +1
  1. Qashqai: Кто эксплуатирует Nissan Rogue, поделитесь впечатлениями! Стоит его брать?
    от Aleksij43 в разделе Эксплуатация и ремонт
    Ответов: 47
    Последнее сообщение: 27.12.2015, 14:18
  2. Одесса: Стоит ли брать А34?
    от Vitala в разделе Разговор по делу
    Последнее сообщение: 01.07.2012, 10:43
  3. Almera: Almera №16 Luxury 1,8 2005 года стоит ли брать?
    от Seriy в разделе Эксплуатация и ремонт
    Ответов: 33
    Последнее сообщение: 22.03.2011, 15:43
  4. X-Trail: стоит брать навару?
    от don_salieri в разделе Эксплуатация и ремонт
    Ответов: 23
    Последнее сообщение: 01.09.2008, 18:42
  5. Almera: альмера классик: брать или не брать?
    от den_sandman в разделе Эксплуатация и ремонт
    Ответов: 31
    Последнее сообщение: 01.08.2008, 23:23
