Страница 1 из 13 1234511 ... ПоследняяПоследняя
Показано с 1 по 10 из 124
Тема: Новый взгляд на Сильвию?
Комбинированный просмотр
    Кандидат Ниссановских Наук Аватар для autofix
    zaporozhec
    По умолчанию "Практика корчестроения, часть 2" Марк Мазуровский 2008 год
    Дядя Марк Мазуровский опять удивляет
    Mazworx/PRL Racing Pro Modified Drag S15
    NDRA Pro Modified
    SR22VET
    Engine
    Mazworx Build SR22VET
    90.0mm 11:1 CR CP Pistons
    86.0mm OEM Nissan Crankshaft
    Mazworx Custom ALuminum Connecting Rods
    Calico Coated ACL Race Bearings
    Darton Sleeves
    Aviaid Dry Sump Pump
    Mazworx Dry Sump Oil Pan
    ATI Dampner
    Mazworx/Power Enterpise 90mm Headgasket
    Mazworx 1/2" Headstuds
    Mazworx CNC Ported Cylinder Head
    Mazworx CNC Combustion Chambers
    Supertech Valetrain w/ Inconel Exhaust Valves
    Nissan SR16VE N1 Cams
    Mazworx Custom Shimless VE Head
    Tomei Cam Gears
    Power
    Fuel-Methonal
    Mazworx Custom Intake Manifold
    OEM Nissan Q45 Throttle Body
    Mazworx Silicone Couplers
    Garrett GT4508R 1.44A/R
    Mazworx Divided Exhaust Manifold
    Tial 60 Wastegate
    5" Stainless Downpipe
    6" Turbo Intake
    Mechanical Fuel Pump
    12 x 160lb Fuel Injectors
    Electronics
    Motec M880 ECU
    Motec CDI 8 Ignition
    Motec ADL Dash Logger
    Custom Engine/Body Harness
    Motec Complete Data Aquistion
    Denso Coils
    MSD/KONI Shock Controller
    16 Volt System
    Drivetrain
    RAM Dual 7" Slipper Clutch
    Browell Aluminum Bellhousing
    G-Force 2000 Transmission
    Custom 4" Aluminum Driveshaft
    Strange Pro 3rd Member
    Strange Spool w/ 40 Spline Gun Drilled Axles
    American Racing 15 x 15 Double Bead Lock Rear Wheels
    AMerican Racing 15 x 3-1/2 Spindle Mount Front Wheels
    Goodyear 32.0 x 14.5 x 15 Rear Tires
    Goodyear 23.0 x 5.0 x 15 Front Tires
    Chassis
    Mazworx Custom 25.1E Chrome-Moly Chassis, RHD
    Strange Ultra Struts
    Koni Electronic Adjustable Rear Shocks
    Mazworx Custom Rear Housing
    Quartermax Pro 4-Link
    Quartermax Pro Wheelie Bars
    Body
    2000 Nissan Silvia S15 Body
    Custom Fiberglass One-Piece Front End, Doors, Trunk
    Lexan Windows
    Mazworx Rear Spoiler
    Interior
    Carbon Fiber Tubs
    Carbon Fiber Defuser
    Carbon Fiber Panels
    Custom Fiberglass Dash
    Safety
    Strange Front/Rear Brakes
    Safecraft Halon System
    Stroud Harnesss
    Stroud Window Net
    Sparco Steering Wheel
    Sparco Steering Wheel Disconnect
    Stroud Pro Stock Air Assisted Parachutes
    Quartermax Remote Disconnect
    Driver
    Jason Greenawalt
    Crew Chief
    Mark Mazurowski
    Owner
    Patrick Linn
    Последний раз редактировалось autofix; 28.03.2008 в 03:28.
    Профессор Nissan Аватар для Decan
    Land Cruiser
    Ой! )))))))))
    ______________________
    Nissan Land Cruiser Prado
    Аватар для Дмитрий
    200sx
    Очень интерессно ))))
    Интерессно трансмиссия как? подвеска задняя прямо как по инструкциии )))) жыррр.....очень интерессно время 60 футов
    Фармацитрон
    Аватар для Valentin
    Kyiv, Ukraine
    フェアレディZ
    Нихренаська...
    Столица Голодомории
    S13, 91, sr20det
    Mazworx Build SR22VET - голова от VE, не от VET?
    90.0mm 11:1 CR CP Pistons - степень сжатия под метанол?
    86.0mm OEM Nissan Crankshaft - сток коленце, ишь ты?
    Mazworx Custom ALuminum Connecting Rods - сами делают? Красавчики...
    Calico Coated ACL Race Bearings - Кстати ACL'и такие можно в Киеве купить
    Mazworx/Power Enterpise 90mm Headgasket - тоже сами делают? Есть какие-то особенности?
    Mazworx 1/2" Headstuds - и эти - интереснее ARP? или толщина больше?
    Mazworx Custom Shimless VE Head - а что это значит?
    12 x 160lb Fuel Injectors - по 3 вряд???
    Denso Coils - какие-то особенные катушки? лучше чем splifire?
    Ну, и как оно едет, самое главное? Или пока не?
    zaporozhec
    Цитата Сообщение от Витёк Посмотреть сообщение
    Mazworx Build SR22VET - голова от VE, не от VET? УГУ
    90.0mm 11:1 CR CP Pistons - степень сжатия под метанол? УГУ
    86.0mm OEM Nissan Crankshaft - сток коленце, ишь ты? держит значит
    Mazworx Custom ALuminum Connecting Rods - сами делают? Красавчики... делает не он, пишет, что он
    Calico Coated ACL Race Bearings - Кстати ACL'и такие можно в Киеве купить И в Луганске тоже :-)
    Mazworx/Power Enterpise 90mm Headgasket - тоже сами делают? Есть какие-то особенности? Да, диаметр 91мм, и отверстия под шпильки ГБЦ в проклаке 1/2 дюйма вместо 3/8
    Mazworx 1/2" Headstuds - и эти - интереснее ARP? или толщина больше? Диаметр 1/2 дюйма, шпильки L19
    Mazworx Custom Shimless VE Head - а что это значит? Это значит, что он шайбочки для регулировки клапанов сам выточил
    12 x 160lb Fuel Injectors - по 3 вряд??? Так точно, говорит смесеобразование лучше и прыскают они не все три сразу, а по умному
    Denso Coils - какие-то особенные катушки? лучше чем splifire? Лучше, другие они, сплитфаеровская катушка не пробивает метанол на 2 барах нормально.
    Пока не, надеются ехать быстро, но оглядываясь на прошлые достижения, думаю поедут очень быстро как для SR20
    zaporozhec
    Прошу прощения за нерадивый ответ, шайбочки Марк не точил, так как есть теория, а может быть и практика, что шайбочки, которые лежат на клапане в тарелке и которыми регулируется зазор, на больших оборотах (9к и больше:shock: ) могут вылететь, поэтому изготавливаются стаканчики.
    Столица Голодомории
    S13, 91, sr20det
    Красавчеги ))
    Ну, скажешь как поедут )
    Кандидат Ниссановских Наук Аватар для MagikArt
    Киеффчегг
    Nissan Pulsar
    ФИГАССЕ! Отдам Свой Пульсар под такую переделку )))))
    ______________________________________
    Nissan Pulsar N12 1970 1.6 МКПП уплыл за деньги
    Nissan Sanny N12 1982 1.5 АКПП ить! переехали
    Злая ВАЗьмёрка 1.5. Хансет, "ездим"
    nissan Pulsar GTi-R 4wd secialized "Ждёмс"
    S12 / Z31 / S110
    СЖ 11:1 и турба... жестко...
    S12 Silvia - CA18DET swapped
    Z31/S110 - restoration
  1. Взгляд со стороны
    от Микрик в разделе Улыбнись! (ех-Юмор)
    Последнее сообщение: 19.02.2009, 10:17
  2. Взгляд изнутри
    Ответов: 22
    Последнее сообщение: 17.06.2008, 18:22
  3. Суппорта 4-eх поршневые на Сильвию
    от Дмитрий в разделе Стайлинг и тюнинг
    Ответов: 19
    Последнее сообщение: 17.08.2005, 10:14
